Long trip mileage report
The mileage results are now in. We made a trip out their farm this weekend. It is 365 km one way. That's about 227 mi. Normally, in the antique I am happy when I only use 7/8 of a tank. In the '97 PSD it takes about 3/4 tank using #2 diesel. Well, this time it used about 5/8 of the front tank to the farm. A little bit less than that on the way back. On the way there we had a stiff cross breeze of about 20 - 30 km/hr. On the way back it was mixed. More like all mixed up. Every time I looked at a flag or windsock it was different. I know 5/8 of a tank is not a very good measure, so when I filled it I used a 25 litre plastic jerry can to fill it. The front tank is rated at 76 liters, 5/8 is 47.5 liters. I'm using my own fuel so I don't have it metered down to 3 decimal places! Anyway, it took 50 liters filled to the brim. 5/8 or 47.5 L is a pretty good sanity check.
Calcs:
365km / 50 liters = 7.3 km/l = 17.17 mpg
Not stellar, but I'm ok with it.
Notes:
1997 7.3L PSD
Newer A/C Injectors
Stock HPOP
Rear end ratio is 3.55
Tire size is 235/85R16
E4OD Transmission
4x4 but used in 2WD mode
Speed kept to 110 km/h about 68 mph
Stock tuning
Used cruise control
It took the hills in OD no problem.
I swear the engine is running the best it ever has, while I've had it.
Running down the highway, the engine is really quiet. If I strain to hear it through the wind noise, it sounds like a chorus of frogs.
It's not all rainbows a unicorns tho. The truck didn't want to start at the second *** stop. The first stop was at the Burger Baron, where we stopped for a mushroom burger. It had longer to cool down I guess. I don't recall it being hard to start then.
The second stop was quick because the woman just had to make a pit stop. But the engine sounded like it wanted to run backwards trying to start. I think maybe the 20% biodiesel in it raises the cetane rating too high. The engine is cranking a lot slower than I would like. I may have battery cable problems or a weak starter. With the higher cetane fuel and slow cranking I think it is firing off too soon.
After hooking up the 8D battery with the battery jumper cables I just happened to be carrying, it spun faster and fired right up.
You have to be prepared if you are doing R&D.
No biggie this time, but a reminder how bad it could be...
Before I got to the farm I switch to the rear tank with #2 in it. Leaving, it was dead cold 11C. I glowed the plugs for 10 sec and it did not even pop. After glowing again for 10 sec it popped but it was cranking very slowly. It did catch, to my pleasant surprise.
I did not shut it off on the way home.
That is the long trip report. Thanks for reading.
