Battery Light On
94f450sd
somewhere,ma
If you have no voltage to either wire in the plug,it cant be charging.one wire goes to the light.the other should have power with the key on.
Did you wire the new plug correctly?
Joe83
Mayflower, AR
Found it... Blown fuse under the hood.
I swear I checked all of those fuses 37teen times throughout the day...
Also found a fuel leak at the fuel filter housing, fixed that and stopped what I thought was a rear main oil leak...
Thank you guys for all of your help!!!!!!!!!
This message board is awesome indeed!
Thanks again.
Good deal. Sometimes a bad fuse can slip by. Especially when there's three thousand of the things. Lol
Edit: makes me think something else could still be at fault. If the fuse was bad, shouldn't it have failed the test?
Default
Yeah, I'll bet it was fuse #6 a 10 amp fuse.
When I posted that other circuit diagram, I was going to tell you to check that one, but forgot. But being 87 next week, my attention span is short.
Joe83
Mayflower, AR
I only have 2 wires going to the regulator. Both are light green/red.
One lights my test light up very bright, the other very dim.
Probably a bad wire?
