Hey everyone, I started this some bit ago, posted in the tech articles and then it kinda got side stepped...aka lost...
Now I"m doing it again.
As some of you know I have a few electric fans and wanted to go that route with my cooling system
As such just prior to me installing my Champion rad, I started the needed work to create a custom fibreglass fan shroud that anyone could then cut and add in their electric fans of choice. I'm thinking this is a cottage industry creating a base for which others can do what they want.
I'm starting with my TALL narrow rad first, but I have the material for the WIDE short rad set aside and if I see enough interest I can duplicate the idea for those too!
So starting from scratch....here we go!
Stock fan shroud.....wow...wasting my time if I attempt to mod this beast I tell ya...not worth it for me...
Here we have the main fans I would like to use, clearly to large for the tall narrow rad
More fans...and these ones well...one looks good other too small
Without my base shroud, I'm guessing here that one from each of the two former pics layed out something like this would work well....
plain base rad.....ya that's a bigun!
Here I have cut some styrofoam to the outter dimension I need for a shroud...notice it's ONLY covering the actual core...no more up above core covering tank or below covering lower tank and in the way of the lower hose...
Stock fan on plywood for tracing and layout...man that's a monster for sure!
Basic layout setup...still showing fan opening and the small missing notch bottom LH corner of pic
Here I have placed my styro on the plywood...getting base setup done.
I duplicated this above for the Wide short rad...I have the styro and the plywood set aside and once I have completed my Tall narrow setup, I'll if enough interest start the Wide short rad shroud
I'll be shaping and setting up the styro for glass layup in the near future and will keep you all updated as I go about this.
Once I build the shroud anyone could cut a circle in it add in their fans of choice and be done! simple, I'll be doing just that myself and also documenting it. That should make it simple for anyone else to do the same
I am planning on adding on flaps like the European shrouds have too...eventually....
Got ?s suggestions...let me know...
Thanks for reading
Al
Thanks for reading
Al
