transfer case ????????
eastsideauto
Denton, NC
Was ther ever a non-slip yoke t-case behind an IDI? Which non-slip t-case can be swapped in?
jaluhn83
Upper Marlboro, MD
1345 will bolt up, that was stock 80-86. Later 1356 cases are fixed too, but I think they're harder to find.
FYI, the t-cases are the same bolt pattern for all 80-96 trucks, so you can put pretty much anything on there.
Yes...CC long box and IIRC SC LB as well...the drive shaft is a two piece and uses a fixed tcase yoke
Any from the above group or a Bronco one with fixed yoke too. Or a 205 or 203 for that matter if you wanted a 203..LOL
You will need a custom rear shaft for sure if you do not already have a fixed yoke setup....
gonecrazyi
florida
Most of the fixed yoke 1356s I have seen were on broncos and crew cab f250s from 96/97. But there are always oddball combinations that have had them.
pwillis
