Goofyexponent
Mentally Unstable..
Ok, I got sick and tired of having to put the canned heat to my truck in the mornings. So out I go, broken finger and all, to replace the GP controller with a known good one I had here. I even replaced the relay with a BRAND NEW FORD one.
Ok, I put the controller on the truck, and turned the key on. I have fire going to the little red wire...this turns the controller on.
Next, the little white wire that goes to the controller is getting grounded through the controller....I checked with my meter.
The ground is clean, solid and tight.
I have power going to the live side of the relay....big lug. It's getting power DIRECTLY from teh batteries...no yellow wires in the engine harness anymore.
THIS IS EXACTLY HOW IT IS WIRED AND SHOULD BE WIRED. I just want to be clear...I checked it 5 times, and verified EVERYTHING....ther are NO mistakes made on my part....I wanted to be SURE of that!!!! lol
This is what happens. I turn the truck on, the WTS lights comes on, and stays on for 15 or so seconds. There is power going into the relay on one side, but it seems the relay won't cross over and let the power through.
I don't want to blame it on the controller and go out and buy a brand new controller if it's a relay problem.
I am off tomorrow, so I may go get another relay.
Normally I wouldn't ask, but with my busted finger....turning wrenches is becoming harder and harder as my finger gets sore and swells up....I on;y want to do this once.
What would you guys change, the controller or the relay?
