Mel's Timing Clinic at the Rally.....
hesutton
The Anti-Anderson
Bowling Green, KY
Mel has graciously agreed to do another "Timing Clinic" at the rally. We will be starting on Friday afternoon once folks get back from the cave tour and have had a bite to eat.
If you want your truck timed..........please do the following:
-Open your hood as soon as you get back to the campsite to let the engine heat out.........it will be too hot for Mel to work on otherwise.
-Make sure you can insert the chuck end of a 5/16" drill bit fully into the upper crankshaft timing port a full 1" (until it touches the crankshaft damper). I'm afraid he may have to turn away any truck that hasn't had this proceedure done.
Ron and/or Gary are planning on bringing injector testers.........and will be poping some (hopefully Moose vs. DPS) for us. I'll let them chime in if they want to pop test for guys or just demonstrate.
I'm planning on rebuilding an injured 1345 T-case as well (once I get parts from Russ;Sweet).
Any intrest.....speak now or forever hold your timing questions.
Heath
I;m in for the timing. I just need a comparsion as to what I have on my meter. I also will bring my pop tester and the reallt neet tool that holds the throttle open so your hands are freed up for adjustments. Sounds like lots-o-fun....:D
Dsl_Dog_Treat
Decatur,MI
I'm game for testing injectors.:thumbsup:
Hey Heath, make sure ya bring some grease to hold that spring loaded check ball in place. ;Sweet
You'll see what I mean when you try to put it back together.-cuss
hesutton
The Anti-Anderson
Bowling Green, KY
When I took it down for "pre-rally inspection"..... I noticed that like piece of heaven at the very bottom of the most narrow portion of the housing. Yippy.:puke::rolleyes:
Heath
Just another comment, that any poor souls who have the early Banks square airbox.... be prepared for my to request you remove it prior to my timing your truck.
vegas39
las vegas, nv
Yea, no kidding! Everytime I need to do something to my truck, I have to remove 14 bolts and 4 hose clamps!
sootman73
Wauseon, OH
i'm in for timing for sure! mine has needed that since i got it. no where to do it around here that i trust plus i dont want to spend an arm and a leg to have someone else time my truck.
jperecko
Diesel Ape
Boonies of SoCal
Heath
What work are you doing to the T-case? I have a little experience with mine...
Have a spare chain ready because they can get stretched if used and/or abused.
Also the oil pump on these has a tendency to wear through the case. Have a new one ready but also be aware that there is a chance that if it is worn through, you need a new case unless you can place a bead of aluminum to replace a worn down rib.
Dsl_Dog_Treat
Decatur,MI
I'm curious as to the location of the wear induced by the pump????
hesutton
The Anti-Anderson
Bowling Green, KY
The pump has not worn the case really at all and the chain seems to be in spec. It was rebuilt and it looks like the shift arm was installed incorrectly making the proper gear selection ...........well........."less than optimal".:D
Heath
jperecko
Diesel Ape
Boonies of SoCal
ah... so it will be more of a "look and see what it looks like inside" thing I guess...
A good thing to do because a T-case is not really maintained all too often.
Do you have the actual spec for the chain? I just got a spare and compared it to that... it was not stretched longer so now I keep the new one as a backup.
Dsl_Dog_Treat
Decatur,MI
Heath
I'll help ya get it back where it should be.;Sweet
Me thinks the speculum might work to get some more working room in there though.LOL
Bo17
