6.6 injectors
idi-guy-tony
mauk ga
I no nothing about duramaxes nor do I want to but a friend of mine is buying an 01 was told it needs injectors so by default I have to learn duramaxes how hard are the injectors to change in these and would that b y it has a code fore fuel pressure
:frustrate
Well first I would put in a aftermarket fuel pump.
Next yes I bet it needs injectors. Might as well do the cups also, as they're known to pull out.
It's a bit involved.
You have to pull the valve covers.
idi-guy-tony
mauk ga
will I need to remove the cab to do so r was gm smarter than ford ????? like I said I no nothing about them
