using 450 spindels on a 250/350 truck
giezy
rockwood/on/Canada
Want to convert front of dully to ten bolt and then swap the rear end to match. To licence the truck were I live is a big hassle cause the weight and I already have a good running truck now
outside of the bearing and seal part numbers interchanging, nothing else does. F450 axles are monobeam and kingpinned.
good luck with that.
giezy
rockwood/on/Canada
Are the brakes interchangeable then whant to convert to ten bolt wh3els and run the Dana 80 rear without the bad ride ov the f450 and all the new rules to go with it .
Hoping if any one new the king pins were the same on the front of a 450 and a 250/350 twin beam ?
i presume you have not looked at these parts.
please do so before wasting any more time.
William88
