Battery Light On
Joe83
Mayflower, AR
Battery light came on yesterday.
Checked alternator, was not charging.
Had it tested and it tested good.
The alternator has one heavy wire and one plug with 2 wires.
In the plug one wire was corroded, I replaced the plug, now it is charging but the light is still on.
Each wire in the plug is neither hot nor ground.
In the fuse box under the hood,
The mini fuses, right side, 1,3,9,11 have no power, 5,7 are not used.
Any help would be appreciated!
1999 F350 "early" crew cab, long bed, non dually. 240,000 miles.
Joe83
Mayflower, AR
I can run a jumper from the battery to either of the 2 small wire that are in the plug that plugs into the alternator and the light goes out.
Thanks
Joe83
Mayflower, AR
Ok, fuses that have no power are for the lights, they work with lights on, scratch that.
If I unplug the plug on the alternator, the light goes out but it does not charge, when I plug it up it charges, but the battery light comes on.
What was the test procedure on the alt?
Even though it may have tested "good," it's probably on its way out.
Check the 5 amp fuse #29 in junction box in the cab under the dash. Edited.
Here's your circuit.
Joe83
Mayflower, AR
Thanks Bull, I called my self checking them all, I will check again.
Joe83
Mayflower, AR
Now, on that diagram, it shows one light green/red wire going through the lamp and to the fuse.
Where does the other one go?
There is 2 in the plug.
Here is another circuit diagram, all the circuits I show are from the factory 99 wiring diagrams. Have no idea of what they mean by GIVEAWAY.
The second pic is of a 3G Alt. maybe you can figure it out from that.
They can show up fine depending on the tester used. Try orielly for a second check.
Do you have a voltmeter to check actual output?
The trouble with stores checking the Alt is, they put 12.5 VDC to the field circuit A, that gives the Alt full output ~14.7 VDC or more and call it good.
^ that's what I mean by different stores. Some have better machines.
Bill, have you ever heard of using a battery load tester to test a alt?
Joe83
Mayflower, AR
Used O'Reilly and autozone with 2 used alternators, one knock off, one motor craft.
Both outputs 14.2-14.5 per my Fluke multimeter. Light still on.
Joe83
Mayflower, AR
I have 0 voltage on either of the wires in the 2 wire plug.
William88
