LCAM-01XA
The electronic brain box that's typically used when your tow vehicle has separate brake (red obviously) and turn (amber/yellow usually) signals while the trailer has the red combined S/T/T lamps, can that thing work the opposite way? Like if you got a truck with combined S/T/T lamps, but a trailer that has separate brake and turns, is there some device out there that can split the combined signals? Running standalone brake and turn wires from the dash and using the HD (for semis) 7-way connectors is always an option, but then only vehicles equipped in such a manner can tow said trailer, whereas a converter box installed on the trailer would allow quite a bit more flexibility... Ideas?
