bugman40284
I have multiple wiring issues lately. For starters my engines stays running after turning the key off, this only happens when I have the headlights on
Next: every time I push the brakes my radio turns off and then turns back on. This has been getting worse lately.
When I have my headlights on my radio won't turn on at all. It may flash like it wants to turn on but fails.
I have taken all the bulbs out of the front and tail lights, pulled all the fuses to see which line might be doing it, and started disconnecting wires to narrow it down.
I suspect that it is the tail lights because when I disconnect them then everything works fine. I have followed the lines back checked the bulbs and cut the entire camper line out in frustration with little change at all.
Here's where you come in: I have been searching for a wiring diagram trying to see where the line might connect. All I have found is a master schematic for a gasoline motor and a schematic for something that is similar to my truck but different enough that it doesn't match up.
I have an 85 f250 with a 6.9 non turbo. Stock wiring stock headlights no
Aftermarket relays.
If there is a chassis diagram that you think would be of some help, I would greatly appreciate a link to this knowledge. Thanks for any advice that you can pass on. My last thought is that it might be the starter solenoid but I have no freakin idea.
The Bugman
Aftermarket relays.
The Bugman
