Jjona5
So I got my smoke issue resolved with a new cdr valve, the starting issue with a new set of return line caps, and the power with a new line running from the alternator stud to the ignition relay. I am now content with the engine and transmission. That being said, I'd like to have a full wiring diagram if possible so I can figure out what I can cut out of the system and what I need to keep...mostly to make sure the e4od works properly.
