Picked up a Mexican gardener's truck from a Mexican gardener.
It's a 95 PSD ECLB 4x4 with 4.10s, 5 speed swap, 4 mismatched tires and pretty much every panel dented but zero rust at all. The current plan is to get it reliable to tow my rock crawler and drive to work occasionally.
So far I've been doing fluid swaps to get it baselined. I have to do the wait to start cycle 3 times to get it to start quickly so I'm thinking glow plugs and the UVCH may be next. Any idea on what are the most common leaks in the valley between the cylinders? It's an oily mess.
Next up is rebuilding the TTB unless a D60 magically appears and replacing what looks to be the original cooling system.
Figured out my rear diff leak. Someone didn't tighten the bolts.
