Notices
Thread: Coolant Fan CFM?
Results 1 to 6 of 6
  1. Coolant Fan CFM?
    #1
    Registered User tbryanh's Avatar
    Join Date
    Mar 2012
    Tracy, CA
    Thanks
    Does anybody know what the CFM af the stock coolant fan is?
    -Bryan
    1986 E350 6.9L C6
    1989 E350 7.3L C6
  2.
    #2
    Registered User rhkcommander's Avatar
    Join Date
    Feb 2010
    Oregon
    Thanks
    30
    Quote Originally Posted by tbryanh View Post
    Not sure, but it varies. Much more than any electric fan could do from what I've heard. You can get some power back by swapping to electric fans, a common method is two ?ford taurus/van 3.8l fans?... there are a couple write ups here somewhere
    1987 F-250 6.9 IH Turbo
    -Banks Sidewinder Non-WG with custom ram air
    -2x Group 31 Batts & 130A 3G Alternator
    -Rebuilt Dana 50 TTB, new shocks all around, adjustable alignment bushings, 4.10 rear
    -Custom dash panel: Pushbutton glow plugs & starter, toggle reverse lights & fog lights
    -New gear reduction starter, Beru glow plugs, BB injectors, IP
    Images
  3.
    #3
    Senior Member OLDBULL8's Avatar
    Join Date
    Feb 2009
    Thanks
    106
    IT varies with engine speed, a locked fan 1800 RPM at 240* IIRC is 960 CFM.
    You said what?
    I'm not Crazy, my Mother had me tested
    "99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
    SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
    "90" F350 7.3 IDI SC LB DW E4OD 4:10 Reman Promar long block Black Knight
    Gone now to my 16 Yr. old Great Grand Son. 10/17/12 Only 7K miles on the Promar engine.
    "92" F350 7.3 IDI CC LB DW E4OD US Gear O/U 4:10Gauges EGT--Boost--Trans.Temp--Banks turbo White Knight
    My mind works lightening fast.
    One FLASH and it's gone forever.
  4.
    #4
    Registered User ocnorb's Avatar
    Join Date
    Aug 2009
    Wasatch Front
    Thanks
    32
    960 seems low...
    ________________________________________________
    1957 IH w/6.9L, ATS 088, C-6, GVO, D70U, flatbed C&C.
    2012 Ram 3500 HO Smoothside dually. Now rocking CNG dual fuel system.
    Other stuff I maintain/tinker on: 2003 Jetta TDI, 1949 Willys, Deuce coupe chopped 3.5", and couple motosickles.
  5.
    #5
    Join Date
    Apr 2012
    SoCal
    Thanks
    Quote Originally Posted by ocnorb View Post
    960 seems low...
    Very low. More like 9900 cfm or more. I used to have a book that listed mechanical fan cfm's by aplication. I remember that your average mid 70's big block car was 8000-10000 cfm and our fans are much bigger than those.
  6.
    #6
    Senior Member riotwarrior's Avatar
    Join Date
    Sep 2006
    Thanks
    833
    Ill bet there is an app for that....or some formula that computes # of blades, diameter of inner and outer blade area covered and angle of attack and RPM....
    91 F350 4x4 RC AKA (White Rhino)Home built wood deck, 7.3/ZF 5sp
    Champion Rad, TYT TH 9000 VHF radio, Ramsey RE 8000 winch, and MORE TO COME, MUCH MUCH MORE!
    ITS THE build path/truck to a BIGGER Bronco SAY a SC Bronco!
    90 Bronco AKA (THE TUG) Hydroboosted, Terrapin Firewall plate, ,
    Looking for another 7.3 and E4OD for this now...SuperWifey can drive it then
    VE7LAA
    ITEMS NEEDED! / wanted...
    - Ramsey RE 12,000 lb or some other 12-16K PTO or hydraulic winch
    AKA...Al or "Camo Pants"
    It's TOO late to read the book on how to swim when the boat's going down
    Quote Originally Posted by icanfixall View Post
    ... Everyone around me is flat ass useless.... A bunch of short bus window lickers........The amps will smoke the wire faster than a prom dress comes off in the back seat of a 55 chevy...
    Quote Originally Posted by LCAM-01XA View Post
    ..... I will light you up so bad you'll think God himself is coming for you! ....
    Quote Originally Posted by towcat View Post
    .. It's not a redneck hell-hole... it's a garden of inspiration!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
