I replaced my Injectors today with new BB code Delphi, also replaced return lines. I didn't replace pump yet but will be doing so when I have the funds. I also replaced the CDR valve, Air Filter, and Fuel filter. I filled the new fuel filter up with diesel before installing it, after a few short turn overs, and one quick turn over at half throttle the truck fired up with a big puff of whitish grey smoke. Idle smoothed out and smoke dissapated, but if I stab the throttle it will puff a pretty good bit of same colored smoke. If I hold throttle open it's not smoking, only does it at intial stab of throttle. I haven't driven it yet to see what the smoke does running through the gears or under load, but will do so tomorrow. Any ideas if this is going to be a problem or just aftermath of all the air that was in the sytem from changing things out?
The truck has 112,000 miles on it, the injectors I took out were BB code with CV England inscribed on them, anyone ever heard of them? I'm wondering if those were original injectors, the return line only had one place that leaked a little, but I figured now is the best time to do it as well. Thanks for any replies and Happy Independence day, what a great counrty we live in!!!!
. Triple disc torque converter has 150 square inches of friction material, stock has just 25 square inches of material.Transcold Carrier pump helping out Moose Pump and just loven it. 4 inch Straight piped, hydroboost with a 1 5/16 inch master cylinder. 7.3 turbo upgraded motor, ported heads, intake & exhaust manifolds. ARP studs. Block sleeved on all 8. Mahle turbo pistons milled, are 24 to 26 thousands above the deck, then ceramic coated with Tech Line CBX. Line bored and balanced. Decked block. Each piston is 1/4 and 1/3rd gram of each others weight. "BB" injectors. Custom Rodney Red aluminum radiator and running cool. Now it needs my new Hypermax intercooler to help out the famous Moose Pump and a set of Moose Injecters thrown in just for giggles...Double FatMat inside of the crewcab... Nice and quiet too...
