Notices
Thread: zf5 teardown questions
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1.
    #16
    Registered User dagreendeville's Avatar
    Join Date
    Nov 2011
    eustis, fl
    Thanks
    well thanks guys i finally had time to tear mine apart the manual that dan emailed was great i had no problems with the tear down now its time to go buy a new 3rd-4th gear shift fork as mine broke the only other issue i had was popping out of reverse im going to have the syncros and everything looked at when ni pick up my parts and i agree there should def be a rebuild write up..... also so far this has been a very simple teardown
  2. ZF 5 speed rebuild
    #17
    danc01
    Join Date
    Jul 2006
    south of Boston
    Thanks
    Quote Originally Posted by kawamatt View Post
    Good info, thanks! I have been looking at these ebay kits. There is either this kit or this kit. One is cheaper than the other but its hard to know which might have better quality components. The money's not really the issue. Like I mention in the captions of teardown pictures, this thing needs to outlast the truck once installed. Also going to spring for all new gear roller bearings.
    Interesting! I searched the ZF part number for the "shim kit" (you can't just buy one) and I was seeing very high prices. Even so, $100 is still a bit high when you will only be using 2 shims from the kit. Maybe a dedicated trans shop could sell individual.
    I'll dig out my receipts for all my ZF parts and list what I bought and what I paid, again I went with all genuine ZF parts. Dan
  3. The Following User Says Thank You to dancrowley For This Useful Post:
    riotwarrior (06-27-2012)
  4. ZF Parts prices
    #18
    danc01
    Join Date
    Jul 2006
    south of Boston
    Thanks
    These are the ZF parts that I have bought and how much that I paid for them. Like I said; I wanted all factory parts and I paid top dollar for them.
    PART #'s
    ZF BB/DSL 4X4 Mainshaft 18.78" 1 EA $ 135.42 ==== ZF-42-2
    ZF S542 Snap Ring Kit 1 EA $ 67.48 ==== SRK-1307
    ZF S542 Shim Kit 1 EA $ 94.07 ==== 1307SMK
    ZF Idler Shaft Bolt-All ZF'S 2 EA $ 3.14 ==== 0636101663
    ZF S542/S547 5 Speed Minor Kit 1 EA $ 133.72 ==== 1307Minor
    ZF Blocker Kit 1 EA $ 179.24 ==== 1307SK (Syncro's)
    ZF Needle Bearing Kit S542/47 1 EA $ 41.71 ==== 1307NK
    ZF Syncro-Ball-Key-Spring Kit 1 EA $ 34.95 ==== 1307PPK
    ZF Plastic Shifter Guides 2 EA $ 3.96 ==== 1307-306-154
    ZF S5-42 Inner Boot 1 EA $ 8.75 ==== 1307-306-236
    ZF Detent Pin 1 EA $ 9.99==== 1307-306-170
    ZF Detent Spring All ZF'S 1 EA 9.30 ==== 0732041946
    ZF Rev Stop Plate Compression Spring 1 EA $ 2.45 ==== 0732041947
    ZF S5-42 Stop Plates 1 EA $ 3.84 ==== 1307-306-229
    ZF Clutch Pivot Ball 1 EA $ 5.25 ==== 1307-301-011
    ZF S5-42 Manual 1 EA $ 10.00
    ZF S542 Back Up Switch 1 EA $ 9.95
    ZF S542 Bearing Guide Tube 1 EA $ 7.00
    S and H $71.50 Total $821.77
  5.
    #19
    Join Date
    Nov 2010
    VA
    Thanks
    So you were converting to 4x4?
    I assume the "minor" kit came with syncros and tapered bearings? Or are these things in the "blocker" kit?
    A complete needle bearing kit, if it includes all the bearings for each gear, for $40 is amazing. I am assuming this was just the shift rail bearings.
    Do you have a number on the "inner boot" for $9? The cheapest I can find it for is $45. Inner shift boot
    It would be super helpful if you saved the packaging and could post all the part numbers for each part of the order you placed. I am sure the P/N's were on the invoice if you threw the packaging away.
  6.
    #20
    Join Date
    Nov 2010
    VA
    Thanks
    So some more info for those looking to rebuild their ZF5's.
    After reading dancrowley's list I realized that maybe a person could buy individual parts instead of a whole "kit" as it were. Some googling led me to this guys rebuild thread. He mentions he purchased a "Transtar" rebuild kit. Some more googling led me to this transtar manual transmission catalog. About page 180 starts the ZF parts.
    Back to google and searching using the P/N's in the furthest right column and I've stumbled on a bearing shim kit for the input shaft for only $17. Nice! DTS-ZF42-SMK This price seems too good to be true though. Also can't find a shim kit for the countershaft. Transtar lists the P/N for the input shim kit as ZF42-SMK and for the countshaft as ZF42-SMKA.
  7.
    #21
    Using the Force! Agnem's Avatar
    Join Date
    Jan 2005
    Thanks
    138
    The only thing that I can contribute, haveing not done this myself yet, is that consultation with my trusted mentor and Ford technician Bob reveals that it is not uncommon for a ZF case to "stretch" under heavy load. This can make rebuilding more "fun" than you can imagine. Good luck!
    Webshots erased my signature and all but our memories.
    - Mel
  8.
    #22
    danc01
    Join Date
    Jul 2006
    south of Boston
    Thanks
    The Minor kit had the tapered bearings and some gaskets and some seals. The blocker kit was the syncros. The needle bearings came in their own kit. The syncro-ball-key-spring kit, shifter guides, inner boot, detent pin and spring, rev. stop plate compression spring and plates were all in one sealed bag. This is a 4X4 trans. Dan
  9.
    #23
    Senior Member riotwarrior's Avatar
    Join Date
    Sep 2006
    Thanks
    761
    Quote Originally Posted by dancrowley View Post
    KIT PART NUMBERS PLEASE?????
    91 F350 4x4 RC AKA (White Rhino)Home built wood deck, 7.3/ZF 5sp
    Champion Rad, TYT TH 9000 VHF radio, Ramsey RE 8000 winch, and MORE TO COME, MUCH MUCH MORE!
    ITS THE build path/truck to a BIGGER Bronco SAY a SC Bronco!
    90 Bronco AKA (THE TUG) Hydroboosted, Terrapin Firewall plate, ,
    Looking for another 7.3 and E4OD for this now...SuperWifey can drive it then
    VE7LAA
    ITEMS NEEDED! / wanted...
    - Ramsey RE 12,000 lb or some other 12-16K PTO or hydraulic winch
    AKA...Al or "Camo Pants"
    It's TOO late to read the book on how to swim when the boat's going down
    Quote Originally Posted by icanfixall View Post
    ... Everyone around me is flat ass useless.... A bunch of short bus window lickers........The amps will smoke the wire faster than a prom dress comes off in the back seat of a 55 chevy...
    Quote Originally Posted by LCAM-01XA View Post
    ..... I will light you up so bad you'll think God himself is coming for you! ....
    Quote Originally Posted by towcat View Post
    .. It's not a redneck hell-hole... it's a garden of inspiration!
  10.
    #24
    danc01
    Join Date
    Jul 2006
    south of Boston
    Thanks
    The part #'s have been added to the list of parts. Dan
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
