Notices
Thread: ok new problem, I need help with brakes!
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
  1. ok new problem, I need help with brakes!
    #1
    Registered User 89blue7.3's Avatar
    Join Date
    May 2009
    fredonia pa
    Thanks
    i think this has been talked about before but im not sure. i am bleeding and bleeding the brakes on the 92 dually and not getting any air. without the truck running the pedal is good and hard. soon as i start the truck up the pedal goes to the floor. pump it up about 3 times and it gets firm for a few seconds then slowly goes to the floor. its not leaking anywhere. previous owner said they had several master cylinders in it but it never cured the problem. the only other thing in the system is whatever "thing" is mounted on the drivers ftramerail that the rear brakeline goes in and comes out of to go to the rear axle. it also has a wire harness on it. what is this thing and could it be the problem? i cant tow my camper to the rally without brakes!! thanks in advance!
    -1989 f250 SC 4x4 4.10 ZF5 7.3 ATS turbo
    -'92-'97 updated front clip
    -hydroboost and custom Superduty rear disc conversion
    -burning WVO & WMO
    -soon to have D60 front axle
    project crew cab dually "Black Dynamite"
    -1992 rust free truck from charlotte NC
    -1996 215hp cummins swap with nv4500.
    -custom paint job
    -I will never have any free time...
  2.
    #2
    X 91idi's Avatar
    Join Date
    Nov 2009
    X
    Thanks
    137
    Rabs(rear anti-lock brakes valve) I bet is the problem. Replace,bleed, delete you chose
    91 F-250 7.3 5 speed 4X4
    86 F-250 6.9 4 speed 4X4 hypermax cowl intake, stans headers, banks power pack, typ4 cam, ported and polished, Carter P4070
    93 F-350 6.9(from an 83) 4 speed 4x4
    Dyoung- "I always get the finger from my truck so i give it the finger right back"
  3.
    #3
    Official GMM hand model icanfixall's Avatar
    Join Date
    Apr 2005
    Thanks
    900
    My feelings are the rear brakes are way out of adjustment. To test this theroy apply the parking barake down about three clicks. Also where does this peddle set the brakes at. If its more than half way to the floor the rears are completely out of adjustment. Now I know your thinking the rears are self adjusting... But in reality they just do not work. So most of us here self adjust them for proper brakes. They do wear down and when they can't adjust up it takes more brake fluid to fill the wheel cylinders for them to stop you. This is true also if when you come to a stop the brake peddle sinks to the floor slowly till the truck creeps forwards surprising you. When your pumping the brake peddle your pushing more fluid back there to fill the cylinders. Another test is when you set the parking brake down three clicks take it for a SLOW test run. See if the brake peddle stops the truck higher up. What the parking brake is doing is manually spreading the rear shose making them "adjusted"... But bot really a good thing to be doing all the time. When the rears are so far out of adjustment the front are doing overtime to stop you. That will overheat the brakes and the rotors. I cracked several roros before I found this out at a Midus brake shop. Now I self adjust and have never had any more issues with the rears. A hydroboost brake system makes this creeping peddle problem almost go away completely but you still should pm the rears. A hydro and 1 5/16 master cylinder pushes more fluid per brake peddle movement and it doubles the hyraaulic brake fluid pressure to 2200 lbs...
    89 SRW crewcab, Banks Sidewinder Turbo, 8 speed BTS E4OD with a Gear Vendors, Shifts smooth and positive with any load on it. Triple disc torque converter has 150 square inches of friction material, stock has just 25 square inches of material.Transcold Carrier pump helping out Moose Pump and just loven it. 4 inch Straight piped, hydroboost with a 1 5/16 inch master cylinder. 7.3 turbo upgraded motor, ported heads, intake & exhaust manifolds. ARP studs. Block sleeved on all 8. Mahle turbo pistons milled, are 24 to 26 thousands above the deck, then ceramic coated with Tech Line CBX. Line bored and balanced. Decked block. Each piston is 1/4 and 1/3rd gram of each others weight. "BB" injectors. Custom Rodney Red aluminum radiator and running cool. Now it needs my new Hypermax intercooler to help out the famous Moose Pump and a set of Moose Injecters thrown in just for giggles...Double FatMat inside of the crewcab... Nice and quiet too...
  4.
    #4
    Join Date
    May 2012
    Louisiana
    Thanks
    I had this problem ib my truck. Check all your vacum limes and dpuble check your fluid lines. You have a leak somewheres. I chamged master cylinders, pads, calibers, booster, lines and everything inbetween and i still am fighting a small problem. Mime ive narrowed down to the vacum system. Beat thing exscPecialy if ur haulijb is get a hydro boost instead of sinkin money into a poor system
  5.
    #5
    Join Date
    May 2009
    fredonia pa
    Thanks
    Quote Originally Posted by 91idi View Post
    ok this is just the thing that actully operates the rear abs correct? i HATE the ABS crap, so if i just got a barrel type connector to join the in and outgoing lines thus deleting that unit it wont affect the braking other than i wont have ABS? i think i will do this if for no other reason than to eliminate it as being a problem now or later. i will also adjust up the back brakes too, however i had to "loosen" the drivers side cuz it kept grabbing and i couldnt get the drum back on. the actual "proportioning valve" is that big hex shaped thing on the rear output of the master cylinder right? is there a different one that can be used to up the rear brake bias when loaded heavy, as this truck typically will. i do have a hydroboost that i didnt install yet for two reasons. first is its my heavy towrig. losing steering AND brakes at the same time doesnt lend itself to the longevity of my family. second is i used a compression fitting to adapt my ford PS pressure line to a dodge end to work with the cummins and im not trusting it 100% yet...
    -burning WVO & WMO
    -custom paint job
  6.
    #6
    FNM Iowa 73's Avatar
    Join Date
    Mar 2012
    IA
    Thanks
    Went through this on my '92. Switched to hydro boost and fixed my problems. The vac boosters that I tried would not give me a firm pedal, and everything else was good.
  7.
    #7
    Not liked here..... '94IDITurbo7.3's Avatar
    Join Date
    Mar 2011
    Fowlerville Michigan
    Thanks
    1,089
    could also be a bad booster.
    Eric S.
    1994 Ford F-250, SCLB, 7.3L IDI, Factory Turbo, 2WD, E4OD, 4.10 LS.
    ARP Head Studs, 60-1 Cold wheel, R&D IDI Performance 90cc DB2, Superduty e-fuel, AEM Dryflow, home made 3" exhaust outlet, 4"exhaust, 3 glowshift gauges, 3 sunpro gauges.
    Quote Originally Posted by wreckerman893 View Post
    I have beaten more than one inanimate object to death because it pissed me off at the wrong time.
    EPA
  8.
    #8
    Join Date
    May 2009
    fredonia pa
    Thanks
    hmmmm... i do have another booster. but how does the booster affect the master cylinder? all it does is make it easier to push, right?
    -burning WVO & WMO
    -custom paint job
  9.
    #9
    Join Date
    Mar 2011
    Thanks
    1,089
    Quote Originally Posted by 89blue7.3 View Post
    let me find the link.
    EDIT: http://www.ford-trucks.com/forums/66...-problems.html
    Eric S.
    EPA
  10.
    #10
    not rocket science GOOSE's Avatar
    Join Date
    Jun 2009
    Mays Landing, NJ, USA
    Thanks
    207
    I would put a good eye on the RABS valve.
    The Logger: 1991 f350 4x4 srw zf 5speed 4:10's ATS turbo rebuilt by Scroll Productshttp://site.scrollproducts.com/en/regeneration ,Reman Engine by Promar http://www.promarengine.com/ 3" ATS exhaust, no muffler, 285/75-16 Cooper Discoverers on 16x9 American Racing rims, rear air bags, front aal, ip fuel screw maxed, BB injectors, Protech cab guard and toolbox, Isspro boost and pyro, VDO coolant temp and oil pressure gauges to replace idiot sticks,Flexsteel seats, 2010 Tahoe center console, class 5 receiver, Luk clutch with smf. Coaxed back into operation by Dieselcrawler and the Oilburner's website.
    Highest HP IDI @ the 2012 Rally: 217hp
    The Dump: 1987 Chevy C70. 8.2 Detroit, 5sp, split rear, 22.5's, no more split rims. 9' Western Heavyweight plow
    Nothing can ever be idiot proofed due to Mother Nature's inherent ability to constantly upgrade the common idiot.
    -Wreckerman893
  11.
    #11
    Join Date
    Sep 2005
    Thanks
    Lots of good suggestions already.
    Were it me, first, I would run the back shoes plumb to lock-up, then back them off a few clicks at a time, pumping the pedal between adjustments to keep things centered, until I had wheel rotation with a fairly hard drag.
    What icanfixall says is often over-looked; it takes a ton of fluid to spread out-of-adjustment shoes into contact with the drums.
    I will amend that; FIRST, I would tear into the drums and check for broken/missing springs and such and also the thickness of the shoes.
    Once I knew the shoes were all set to rights, I would DELETE any anti-lock foolishness, PLUS that silly load-sensing gizmo that many dualies have.
    The wife's 1991 Dodge/Cummins never did have decent brakes,and ate rotors and front pads, until I bypassed the RWAL junk.
    Take that steering hose to a hydraulic shop and have it properly made, crimping new hose on the Dodge and FORD ends; that gear-driven Cummins pump might push things apart.
    1985 F-350 repowered with a 1989 6BT CUMMINS
    THE DIESEL POWER UNIT UNDER YOUR HOOD IS AN ENGINE
    MOTORS ARE ELECTRIC
  12.
    #12
    Registered User DesertBen44's Avatar
    Join Date
    Sep 2011
    Grand Junction, CO
    Thanks
    115
    I'm having the same issue 87blue, i'm going to try adjusting the rear brakes on mine and Ill let you know what it changes. Good possibility it will fix it because I installed new shoes/cylinders/drums recently without properly adjusting, which got rid of my grinding issue but cause this...
    []1992 F250 extended cab ZF5 4x4 7.3 N/A w/4.10s Duralift E-Pump, hydroboost, New interior. d60 coming soon
    1993 Dodge W250 4x4 Getrag 5 speed Extended cab Longbed NP205 xfer case. Bought to swap the cummins into my ford, now possibly thinking about restoring this beast, body is shot, trans needs a rebuild, Idk. has a clean title feel bad parting it out!
  13.
    #13
    Join Date
    May 2009
    fredonia pa
    Thanks
    ok im deleting that RABS crap. about the PS hose, isnt there some type of chevy adapter or something of that sort that will allow the factory ford hose end to thread right into that dodge pump? if so i will definately do that!
    -burning WVO & WMO
    -custom paint job
  14.
    #14
    Join Date
    Feb 2009
    Thanks
    When they came out with the ABS, they did away with the proportioning valve, there was no need for it. Most people like me who have bypassed their ABS valve, are just running straight 60's style brakes with no proportioning valve at all, just straight pressure to the front and straight pressure to the rear. If you are worried about it, you could get the proportioning valve off a earlier truck that didn't have ABS, but there will be lots of plumbing involved. I haven't had any trouble with my brakes just running it without a proportioning valve.
  15.
    #15
    Join Date
    May 2009
    fredonia pa
    Thanks
    so what exactly is that big hex thing then? it is a restrictive device of some sorts right?
    -burning WVO & WMO
    -custom paint job
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
