Notices
Thread: E4OD limp mode and bad speedo readings.
Results 1 to 10 of 10
  1. E4OD limp mode and bad speedo readings.
    #1
    Senior Member Danoflapper's Avatar
    Join Date
    Aug 2009
    Zeeland, Michigan
    Thanks
    Hi all, I just had this incident last night on my way to a buddies house down a bumpy dirt road. The speedo wasn't reading normally, and it was flickering within ten mph of my actual speed. And it wouldn't read anything below ten mph. It did that for a while then went into limp mode on my way home.
    Today i checked the connection for the sensor and it was clean and undamaged. I pulled the VSS out and cleaned a small amount of metallic paste off of it with no change in the speedo reading. I plan on picking a couple junkyard VSS' up tomorrow after work and giving them a shot. If that doesn't fix my issues, would the wiring harness be the only reasonable thing left to blame?
    Sorry it's not much of a question, I am just hoping to get some advice from the resident experts Thanks a ton guys.
    1994 Ford F350 - 7.3 IDI Turbodiesel - E4OD/BW1356 - 4X4 - Crew Cab - Long Box - 238k- 3" Straight Pipe - 265's on Factory Alcoas - Now converted to slantnose!/
  2.
    #2
    Contributor justinray's Avatar
    Join Date
    Jun 2011
    Cleveland, Tx
    Thanks
    13
    Happened to me about a month ago.. Instrument cluster failure.
    1993 F250 XLT
    7.3 IDI, E4OD, 4.10 Gears
    Dana 50 Front Axle
    BB Injectors, DPS IP, Banks Transcommand, Banks Sidewinder Turbo Kit, Facet Duralift Fuel Pump, Hydroboost, Hypermax Smoke Puff Limiter
    Warn Locking Hubs, Moog Tie Rods and Ball Joints, Billstein 4600's
  3.
    #3
    Join Date
    Aug 2009
    Zeeland, Michigan
    Thanks
    How did you diagnose that as the problem and not faulty wiring? Is there a way to test my cluster with a multimeter?
  4.
    #4
    Join Date
    Jun 2011
    Cleveland, Tx
    Thanks
    13
    Biggg long test, its a digital IC, what does the mileage say?
    1993 F250 XLT
    Dana 50 Front Axle
  5.
    #5
    Join Date
    Aug 2009
    Zeeland, Michigan
    Thanks
    Wonderful Long and drawn out sounds wonderful haha I appreciate your help big time.
    The ODO reads normal and the miles roll on as usual. No error messages to speak of.
  6.
    #6
    Join Date
    Jun 2011
    Cleveland, Tx
    Thanks
    13
    Haha, sorry if im no help here, iI tried to get help and NOONE really knows whats going on with the instrument clusters.. I ended up not replacing it for a month, til the odometer stopped working, converted to metric, then just gave a brief, lovely ERROR message.
    Error means burnt up IC, Error02 means uncalibrated.
    1993 F250 XLT
    Dana 50 Front Axle
  7.
    #7
    Full-floater Kevin 007's Avatar
    Join Date
    Mar 2011
    Nelson BC Canada
    Thanks
    On my old 1990, the speedo cable was still a manual cable from the back of the t-case and I simply unplugged the cable from the actual speed sensor and let the cable hang. Of course my speedo didn't work but it got me around without limp mode for a while till i got a new speedo cable in. This was a worn cable issue that got to the point where it effected the trans; while I was away working during the winter to boot!!!
    -1984 F-250 ext cab 4x4, 6.9, t-19 with BW1345 t-case, Dana 70 (axle code 73) 3.54's, all stock except for 3.5'' exhaust, and leveled. 187,000km (canadian) Will be burning 5% bio from now on for lubricity. Looking into an OD unit to gain a couple MPG. Racor 225 with 2 micron filter replaced the factory stanadyne unit. New Delphi BB codes.
    -1995 F-250 Powerstroke, 4x4, E4od ext cab. 330,000km. Original injectors, 3.5'' exhaust. And im liking it Haven't had any problems "yet"
    -1979 Mack Econodyne, E6350, 12speed, air to air intercooler...tough and reliable
    -1985 BJ60 Landcruiser, 5 bearing cam 3B diesel, H55F 5 speed...best rig I have ever owned.
    -Couple of really neat vintage dirtbikes
    -Im a welder and a truck driver.
  8.
    #8
    Join Date
    Jun 2011
    Cleveland, Tx
    Thanks
    13
    94 is a rearend mounted speed sensor though. /:
    1993 F250 XLT
    Dana 50 Front Axle
  9.
    #9
    Join Date
    Aug 2009
    Zeeland, Michigan
    Thanks
    Quote Originally Posted by justinray View Post
    Okay so it sounds like if there is not a wiring fault with my truck, the cluster may be in the early stages of a meltdown? Wow, that is quite the downward spiral :O It actually switched to kilometers?? How much will a new cluster run me? Or did you find a used one?
    I take it that you ran your truck with the blinking OD light for a month with no issues?
    The transmission doesn't seem like it is in limp mode to me? It shifts fine and has every gear and the torque converter locks up as it should? It doesn't drive any different, but that dang light is on and the speedo flickers a little.
    I replaced the speed sensor with a brand new one and it seemed to help a little. It reads low speeds now and it doesn't flicker AS much. I checked all the fuses in the dash and everything was fine.
    If i get a scanner will that lead me in the right direction? Or if it is indeed an instrument cluster failure, is there a code for that?
    Quote Originally Posted by Kevin 007 View Post
    I wish i had it that easy, but I have the electronic sensor on the rear end. I unplugged it and the blinking OD light didn't go away.
  10.
    #10
    Join Date
    Jun 2011
    Cleveland, Tx
    Thanks
    13
    I cant tell you if my OD light was on because it hasnt worked since I bought the truck, iirc the IC from ford is about 350 dollars, I got one from a pick-a-part in town for 30, they didnt warranty it, but thats such a small price to pay I wasn't worried. It worked, and still does. Did change my mileage though. I waited to change mine until it started dogging the transmission back and forth between gears, start playing with my drivetrain and I'm getting rid of you. Ha
    1993 F250 XLT
    Dana 50 Front Axle
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
