Notices
Thread: Turbo Install
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 91
  1.
    #31
    Senior Member typ4's Avatar
    Join Date
    Dec 2005
    Thanks
    53
    PM please not visitor message
    -Russ KD7VGT
    '91 f 350 4x4 cc srw,zf,7.3 ATS wastegated,intercooled
    3.55 gears. Rebuilt back to front. Engine mods, torque cam, coated bearings ,rockers, Mahle .020 over, 10 shorter pistons,2 sleeves, balanced, rods bored 6thou shorter. Head prechambers machined to same depth, bronze guides, inconel exh valves,polished ports, valves may have had the backs polished.
    Turbo 093,with 60-1 wheel and housing, coated hot sides,pipes and manifolds. 3"dp 4"exh.
    Dida dyno pull finally after 80k miles of nothing but normal maintainence
    218/461. I was impressed, then my pump shop tells me the injectors they gave me years ago were some throw together rebuilds cause I was on a budget when I built it. Figures the injeector guy would have junkers.
    Runs ok, ask towcat
    fugitive sandrail with 2840 cc typ 4 turboed and injected engine much fun![/SIZE]
  2. The Following User Says Thank You to typ4 For This Useful Post:
    '94IDITurbo7.3 (06-17-2012)
  3.
    #32
    Not liked here..... '94IDITurbo7.3's Avatar
    Join Date
    Mar 2011
    Fowlerville Michigan
    Thanks
    1,063
    Exhaust installed
    yes, that is a muffler under there. once i stop the firewall from rubbing and put some miles on it, it will get straight piped, thus eliminating that mess of clamps behind the muffler.
    i had to cut some of the "down slope" off of the over the axle piece to get the tail pipe right were i wanted it.
    Eric S.
    1994 Ford F-250, SCLB, 7.3L IDI, Factory Turbo, 2WD, E4OD, 4.10 LS.
    ARP Head Studs, 60-1 Cold wheel, R&D IDI Performance 90cc DB2, Superduty e-fuel, AEM Dryflow, home made 3" exhaust outlet, 4"exhaust, 3 glowshift gauges, 3 sunpro gauges.
    Quote Originally Posted by wreckerman893 View Post
    I have beaten more than one inanimate object to death because it pissed me off at the wrong time.
    EPA
  4.
    #33
    Registered User Ididriver's Avatar
    Join Date
    Mar 2011
    Panama city beach
    Thanks
    31
    I really like how tucked up the tail pipe is to the fender.
    I've been wanting to fix that on my truck for awhile now...
    chris
    1991 f250 7.3 idi rclb 2wd e40d hypermax turbo facet electric fuel pump. 3in exhaust to 4 in tail pipe. Lifted/ leveled on 33s.
  5.
    #34
    Join Date
    Mar 2011
    Thanks
    1,063
    ya i really like that as well. my dad and i figured that as long as it is above the axle it is good as far as clearing an objects on the ground.
    Eric S.
    EPA
  6.
    #35
    Join Date
    Mar 2011
    Panama city beach
    Thanks
    31
    I might just see if I can get one of those tail pipes.
    Mine hangs way too low. Probally alil more than a foot between pipe and fender.
    Anyways. When are you going to fix your leaks and see what the new turbo dose for you?
    chris
  7.
    #36
    Join Date
    Mar 2011
    Thanks
    1,063
    the tail pipe is a two piece setup. i will go get the part numbers for you.
    i will seal up my up pipe more tomorrow. then my dad and i have an idea on how to gain MUCHO clearance for the dp. right now i am not at liberty to discuss that method.
    Eric S.
    EPA
  8.
    #37
    Join Date
    Mar 2011
    Panama city beach
    Thanks
    31
    Thanks Eric. I've got front end stuff to do first
    This sounds good
    chris
  9.
    #38
    Join Date
    Mar 2011
    Thanks
    1,063
    part numbers
    aluminized:
    A121025
    A121026
    stainless:
    S161001
    S161002
    BTW, i searched the SS numbers on diamond eye's website and could not find anything. on my packing list it says they are for an 03-07 ford 6.0L but with some fine tuning they work fine.
    Eric S.
    EPA
  10. The Following User Says Thank You to '94IDITurbo7.3 For This Useful Post:
    Ididriver (06-17-2012)
  11.
    #39
    Join Date
    Mar 2011
    Thanks
    1,063
    what does turbo flutter/surge sound like?
    is flutter the same as surge?
    when does it occur?
    why does it occur? related to the intake???
    Eric S.
    EPA
  12.
    #40
    Join Date
    Mar 2011
    Thanks
    1,063
    this is what i cut off of the over the axle piece.
    Eric S.
    EPA
  13.
    #41
    Join Date
    Jan 2012
    Ontonagon, Mi
    Thanks
    That's about what I had to cut off of mine to get it to fit how I wanted. I ran mine straight piped and then put the muffler in to compare the difference in EGT's. Once I found that it made no difference I left the muffler in because it takes some of the droning out and makes the truck comfortable to haul trailers around with for hundreds of miles at a time.
    1987 F-250 4x4 6.9/5spd. WG'd ATS running ~7psi, 3" Stainless PS downpipe into a 4" Diamond Eye Stainless system, Faucet pump, "Typ4" BB injectors, Electric cooling fans, GS 3in1 pyro/oil pressure/boost, DB starter, SMF flywheel and clutch.
  14. The Following User Says Thank You to chevytaHOE5674 For This Useful Post:
    '94IDITurbo7.3 (06-18-2012)
  15.
    #42
    Join Date
    Mar 2011
    Thanks
    1,063
    thanks. was there any difference in whistle with it straight piped vs. muffler?
    Eric S.
    EPA
  16.
    #43
    Using the Force! Agnem's Avatar
    Join Date
    Jan 2005
    Thanks
    138
    I would so agonize over that dent.
    Webshots erased my signature and all but our memories.
    - Mel
  17.
    #44
    Join Date
    Mar 2011
    Thanks
    1,063
    Quote Originally Posted by Agnem View Post
    ya i know. not ideal but still a LONG WAYS away from what the factory pipe was.
    Eric S.
    EPA
  18.
    #45
    Join Date
    Jan 2012
    Ontonagon, Mi
    Thanks
    I have plenty of turbo whistle with the muffler in place. Without the muffler it was just louder overall.
  19. The Following User Says Thank You to chevytaHOE5674 For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
