Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I see a lot of DT swaps in here so i figure this will get the most views here. I got a '71 IH 1210 step side pickup with 36,000 miles on it. it has a 304, 3-on-da-tree and 4x4. someone molested it and put a 14B rear and 10B front axles in it, with ratchet straps and 1 u bolt... cookoo well i already have the IH SV powered travelette i will be building as a tow rig/truck puller/DD. So seeing as the T-ette is soo clean it would be a sin punishable by death to cut out a PERFECT firewall to fit the DT... :backoff i figure since the step side needs floor pans what's the big deal if the sawzall went north on a trip up the firewall?? :sly i'm using the inner fenders and dash from it in the travelette anyway so i will have it stripped down pretty bare. I put some money down on the DT466 cab and chassis today, so stay tuned! ;Sweet
idi_econoline
No Bed For Me!
Northern California
With DDT banned in '72 and 40 yrs (redid the math) since then, hopefully not too much residue in the bed, but I'm no expert; just sayin'.
Around here, the mosquito control authorities used 1st gen Scouts as spray vehicles, come to think of it.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
theres a better pic.
i think it's ddt free... lol
that's cool! they were popular for that, water trucks and all kinds of little off road rigs!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
ok plans have changed. it's now going in my travelette. i parted out the yellow truck, and the parts truck arrived the other day!!
and after i got it i realized its actually intercooled which makes it a DTA466! :D;Sweet
hesutton
The Anti-Anderson
Bowling Green, KY
Sweet Jon!
My project is in enternal limbo it seems. So much going on with work, moving, managing a new practice, a new property to look after....... and being an hour and a half from all the parts for the project is really hampering things here. Once I can get a shop built on my land here, I will hopfully get going again on this project.
Heath
6.9poweredscout
Bleeds IH red...
Northeastern Pa
This thing follows along with the usual IH territory marking like most I've owned. About an inch of grease packed on it. And Heath, if you come across any p pump deals let me know I've been looking around....about $2200 is a little hard to put down on a pump that has unknown condition!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
well i chopped up the cab and chassis today.
my friend taking it for a drive....
any info on this trans.... first gear ratio? od..?
that's it for today!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
We had to build a gantry crane just to move this sucker. i wasn't going to pay $650 at HF, so some scrap, a chain hoist, and some wheels and VIOLA! perfect crane!
made it mobile!
hidden under the grease:
ready to go in for some fitting:
off with the bed!
moved back the cab to make room to set down the engine.
ahhh progress! i have the next 12 days off so stay tuned.
That i-beam on your crane looks like a piece of mobile home frame lol. But nice ingenuity. And nice sticker on your garage door window. Haha
hesutton
The Anti-Anderson
Bowling Green, KY
Yeah, the ratios are:
1st - 7.28
2nd - 4.09
3rd - 2.28
4th - 1.28
5th -1.00
HERE is the parts catalog for that trans.
If you could find a CM-6253-A (0.85 OD) or CM-6253-B (0.69 OD), you have some OD for that big DT466 on the highway.
Heath
swervyjoe
denver, co
I wouldn't want to be under that I beam sitting on those tiny uprights, but I tend to over build things. I'll be watching this build.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
THANKS HEATH! hmmm that'll bolt up the same right? i WANT to find an OD transmission. which one is the deeper od? i have to call the heavy truck place and see what i can find.... there any way to interchange OD parts in this one? i want the trans gone through anyhow before i put it in. and swervyjoe i figure they're rated for 9,000 lbs, as long as i don't start swinging the 466 i think i'll be fine.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Made some room:
between the rails for the first time!
ok so the cab would need a 7" body lift......
touching the floor......
making some room.
oh, hello there..
have to rework the front braces and notch the frame to come forward about 4".
enough for tonight, back at it tomorrow!
Bsthomas21
