Notices
Thread: My 78 F-150 2x gas to diesel build w E4OD
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
  1. My 78 F-150 2x gas to diesel build w E4OD
    #1
    Registered User SHARPIE's Avatar
    Join Date
    Mar 2012
    Daphne,Sweet home Alabama
    Thanks
    9
    First thing is this motor fits snug as a bug in a rug!
    the E4od fits nicely above the front cross member
    rear cross member with C6 trans mount, the cross member has to be lowered 2"
    brake power booster clearance is nice
    steering box clearance is good about 1 1/2"
    rear fire wall, did a little remodeling so I didn't have to fight with the firewall lip.
  2.
    #2
    Join Date
    Mar 2012
    Thanks
    9
    And now the fun stuff!
    Oil pan has to shortened 2" should do me fine
    A/C box has to be notched...This is where a body lift will fix and no room above the tranny for a turbo without major floor workfrom what I see as of now
    Oil filter has good clearance, will get one on to confirm
    This is the original frame mount from the gasser gives a little perspective on the diesel placement
  3.
    #3
    Join Date
    May 2011
    Chelsea, Mi
    Thanks
    29
    HA it will fit with an AC cab!!
    1987 F-350 CCLB DRW project. 7.3NA, C6, 4.10 LS, Fleet Charge coolant, Nothing special yet
    1991 F-150 SCSB Converted from EFI to a carb'd 300-6, NP435/205, Full MSD Ignition, Headman Headers in to straight pipes and dual Cherry Bombs, Holly Four barrel Carb, Offenhauser Intake, Comp Cam. Now swapping 60's front and rear eventually, with a 203/205 doubler kit.
    1993 F-150 SCSB 300-6 EFI, E4OD, 4X4, Just a good daily driver that just turned 110000 miles.
    1967 F-250 Camper Special SCLB 360 V-8, NP 435, Dana FF 60 rear. This may just become a gasser style drag truck.
    2001 Honda XR650L for the fun trips
  4.
    #4
    Join Date
    Mar 2012
    Thanks
    9
    Quote Originally Posted by Coyote_Red View Post
    It will fit in between the A/C box but its against the brake booster and the power steering unit , The picture is with the box layed against the motor to show how much needs to be cut off...Its about 3" so for now I'm going to block off the opening I might just change to a vintage air system since the A/C compressor wont fit anyway.
    This motor is BIG in noway is it comparable to a 460 its about 4" wider and I'd say 3-4" taller
    The E4OD is approximately 6" longer so shaft needs to shortened
  5.
    #5
    ALL MOTOR! Keeway's Avatar
    Join Date
    Apr 2012
    Keewaydin, PA
    Thanks
    coool build!
    1985 Ford F350 4x4 dually, 6.9 N/A 4 speed, flatbed, 235 85 16 Goodyear MT/Rs, straight piped 4"stacks, fuel turned up, other goodies
    Plenty of other toys not enough room to list!
  6.
    #6
    Join Date
    Mar 2012
    Thanks
    9
    Well got my engine final set today, Got pan cut down, Cross member customized...Built the engine mounts today, Fittin the turbo was a.....B***H should be a final bolt in next weekend...Going to start working the wiring over the week.
    1978 F-150 2 wheel drive 7.3IDI Hypermax turbo E4OD
    1967 SS Chevelle wagon :
    1978 F-250 4x4 37" SSR's 6" super lift gasser
    1968 SS Camaro convertible clone
  7.
    #7
    I Want Boost! flareside_thun's Avatar
    Join Date
    Aug 2008
    Grand Island, Florida
    Thanks
    167
    Cool deal, any pics of the truck?
    Junior
    - Burt: 1989 F250 4x4 7.3, SoupBowl/Restrictor Plate Delete, Ice-Cold AC, 3 Inch Straightpipe Out Behind The Tire, ZF 5 Spd, 2001 SuperDuty Axles, 3.73 Gears, 35" BFG AT's on Dick Cepek Wheels
    War Affects More Than Its Participants
  8.
    #8
    Join Date
    Mar 2012
    Thanks
    9
  9.
    #9
    Join Date
    Mar 2012
    Thanks
    9
    Some of what it used to look like
    Before I did the first restore....
  10.
    #10
    Join Date
    Aug 2008
    Thanks
    167
    That is gorgeous and is definitely going to be a unique truck.
    Junior
  11.
    #11
    Join Date
    May 2011
    Chelsea, Mi
    Thanks
    29
    It is a very nice looking truck. So, if I am following you correctly the A/C compressor sticks too far up and will not clear the hood when closed? I plan to run the hydraboost system so I won't have a break booster to clear.
    Looking at the pictures above is making me think that a 70's body swap on to a diesel 4x4 frame will be the easiest route to take. Rather than swapping in a diesel and then converting to 4x4.
    Thanks for the pictures with comments as you are building your tuck up.
  12.
    #12
    Join Date
    Mar 2012
    Thanks
    9
    Its not the A/C compressor its the air box that may not fit but I'm not at that point yet, But I can tell ya if you go turbo the A/C wont work on a 2x because the hoses end up right in the down pipe...But wont know until I work on that part of the build, The power box is the problem not the brake booster and I want to be sure I can get the valve cover off if need be.
    A 70s swap on to a 80-90s frame is going to be more difficult then youd think the frame mounts are all different 81 up have a wider frame and the motor sits further back...This has not been a difficult build heck I'v only been at it for 3-4 weeks on the truck itself...If I didnt go turbo Id be almost done
    Here a 57 I build with the original frame turned into a 4x4
    [IMG][/IMG]
  13.
    #13
    Join Date
    May 2011
    Chelsea, Mi
    Thanks
    29
    I see what you are saying. I will continue to watch as you progress and ask questions if you don't mind.
  14.
    #14
    Join Date
    Mar 2012
    Thanks
    9
    Not at all ask away...
    Some more progress pic's
    This part of the floor board needs to be bent back about 1 1/2-2" to clear down pipe and up pipe.
    My cut up pan was going to notch but decided to just go flat, Would only have about a 2 1/2 drop in the notch so it wasnt worth the time
    My oil filter clearance is awesome! I can run the large filter, This is before the engine mount set in place but with it set on the mount its the same I did this one so it can be clearly seen.
    my up pipe clearance
    My down pipe clearance
    And the good stuff
    The passenger side needs this spot notched slightly for the gear reduction starter only about a 1/4 of an inch
    Had a rain day today and got her all welded up and set in place fits GREAT!
  15.
    #15
    Registered User Danielle's Avatar
    Join Date
    Jul 2011
    NJ
    Thanks
    58
    More more!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
