Mitchell Overdrive......
Finally, an auxiliary overdrive with a REAL overdrive ratio - 27%;Sweet
So why wouldn't it work with autos?
prolly because there is no automatic disengage like a GV has with the control box. there is items like the Muncie "electric shift" for PTO's that can be adapted to the Mitchell, but it takes money for R&D that they prolly don't have. for all intents and purposes, it is a "lightweight" brownie box.
Diesel JD
Gainesville, FL
I thought I've heard of people using a brownie box behind a C6 or Dodge 727 auto. I guess it could be tricky but couldn't you just shift the Mitchell/Brownie if you were sitting still or float the gears? Or does this risk tearing something up? I guess it's a big project, but probably easier than the brownie which was never intended to go in our trucks to begin with. At least this one might be since it was already in an OBS pickup.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I could be mistaken on this, but I think the Mitchell is meant to be a shift-on-the-fly. I met a guy who had one behind a C6 in an F-350 crew-cab dualie, and he was very happy with the setup. Unfortunately, he ended up going the Dodge/Cummins route many moons ago...
If I had a 2 wheel drive, I'd be very interested in that unit...
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
What I wouldn't give for a 5 speed, IDI turbo, cowl induction, intercooled, 4.10 spun rearend WITH one of these boxes slapped in between the transmission and transfer case....that way I could use 4x4 if needed.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
I think with newer trucks, that have the speedo sensor in the rear end and endless computers to run everything, it would confuse the shifting programs. Should work with our generations.
I think it would fit the Chevy.....
The statement about the Brownie not really being fit to our rigs... Nope not so... I worked on Roberts Brownie setup when he was out here on the west coast. Now thats a nice clean setup right there. The way he designed and installed it makes it look like a factory option plus.... The 15 forward choices in gears is out of this world for choices.:sly
jam0o0
houston, tx
i want. darn the $200 shipping though. for $500 it's still a good deal i think.
The Warden
MiB Impersonator
Do you have 4.10's or 3.54's?
If you have 4.10's, then I'd say go for it, from a technical standpoint.
I'm not sure how much trouble you'd get in with SWMBO when (not if) she finds out, though...are you "just" risking castration, or is there a chance of outright homicide?
E Moeller
