7.3 Heads on a 6.9
Whats wrong with running a set of 7.3 heads on a 6.9.... Besides the lower coolant passage being plugged with a freeze plug on the 7.3 heads they are the same as 6.9 heads... Even the gaskets are demensionally the same.... Just two coolant ports need to be changed in the 7.3 head gaskets... Or run a set of 6.9 head gaskets on a 7.3.... I'm not seeing a problem or reason why this can't be done. The exhaust manifolds will bolt up... the valve covers will bolt up.... The rockers will bolt up... the stock valves will be fine even if you run a turbo but... I would feel better with the turbo exhaust valves... They are made from inconel... I have heard thats all we can buy any longer... Nice way to force us to upgrade and the supplier doesn't need to stock two differant valves for these heads.... So why can't we install 7.3 heads on a 6.9... The head bolt diameter differance is 62 thousands so that only 31 thousands on each side of the bolt being smaller in the 7.3 heads... The washers will make that up easily.... Precups wont make any measureble differance either.... The valves are set into the heads the same amount.... Big question here guys... What do you think I missed...:dunno
Diesel JD
Gainesville, FL
You are one of the most thorough member here when it comes to detail and doing things the right way....IDK, I was thinking the difference in bolt size might be a problem but I guess not. Hopefully others will have something to say about this.
idiabuse
Princeton Fl
I ran 6.9 heads on the 7.3, just needed to enlarge the head bolt holes, and make 8 spacers for the lower row of head bolts.
I dont see any problems doing the reverse either.
Javier
429idi
Layton Utah
I tried 7.3 heads on my 6.9. I got the upper 2 rows of bolts threaded in, went to drop one in the bottom row and '****', it dropped all the way in. 6.9 head bolts are not long enough for the bottom row.
idiabuse
Princeton Fl
Yep you need 8 new head bolts, the lower row on 7.3 heads have a raised boss, I had to use spacers to put 6.9 heads on the 7.3.
Some new 7/16 bolts are in order to finish your head swap.
Javier
shocktrooper
colorado
I'm in the presses of outing 7.3 heads on my truck. I took out the freeze plugs for coolant flow. The dowel pins should line the head up and just gets her bolts for the bottom row
BDCarrillo
Abilene TX
ARP makes shouldered washers specifically designed to use a 7/16 bolt in a 1/2 hole. Very common on SBF 302/351 head swaps
19887.3IDI
Michigan
I recently rebuilt a 6.9 and used 7.3 heads on it. I had the machine shop mill .550 of the bottom row and used the 6.9 ARP stud kit along with the 1/2 to 7/16 insert washers.
with the dowel pins locating the head, the .062" difference in the holes are the only things i would be worried about.
easily remedy'd with Bryans post.
he may spell his name with a Y, but he is 100% correct :D
BDCarrillo
Abilene TX
All prices are from summitracing.com
Trick Flow Specialties TFS-51400419 (20x pcs $49.97)
Edelbrock 9680 (20x pcs $56.97)
Airflow Research AFR 6324 (20x pcs $75.66)
ARP 200-8596 (1x pc, $4.43)
ARP 200-8597 (2x pcs, $8.44)
ARP 200-8598 (10x pcs, $40.54)
The ARP OD is the actual outside of the washer, the insert OD is .529"
Waystro
No Class
South Texas
I've wondered about this.
Back in a diesel power magazine some guy put a 6.7 cummins top end on a 5.9 cummins
anything can be done with time and money.
shocktrooper
colorado
You got that right ^^. How many of those washers am I gonna need? Or should I put them on all my head studs?
placidoert
